Yousername
Cheers,
when I'm trying to erase a full "Drive/Partition" I'm able to recover data and running into this error(something like "A non-existant Device has been specified":
When I check the file explorer the HDD is there, but must be formatted again to have access. When doing the same procedure but instead with "unused disk space" I get the warning that there has been a recovery partition or shadow copied volume. I then am not able to recover the full files and filestructure of the HDD but still can restore alot of RAW Data. Both times I used the Schneier algorithm. Is there an optimal way to eradicate every bit of data on the HDD and make it non-restorable?
Using Windows 10, most recent Eraser version, SATA HDD connected via USB.
Update: Pseudorandom Data on unused disk space just deactivated all my USB devices and hence stopped the erasing process
