alex786
If you're already using Exchange 2010 and get drawn to Exchange 2019 because of its unique features, keep in mind that there is no direct migration path from Exchange 2010 to Exchange 2019.
Furthermore, if you attempt the migration using the double-hop method, you may wind up in chaos because the processes are a little technical and hard. Manual migration can be successful, but it comes at a high cost in terms of time and effort. Shoviv Exchange Migration is the ideal solution for Exchange 2010 to 2019 migration along with the feature of instant migration to the source mailboxes.
This software has a user-friendly interface and is very simple to use. In the folder list, Exchange Migration Tool effectively preserves the right hierarchy of the added source mailboxes. The preview option in Exchange Migration Tool makes it much easier to see the newly added source mailboxes. In the Item list, you can see a list of folder items.
The preview feature in Exchange Migration Tool makes it easy to see the newly inserted source mailboxes. In the Item list, you can see a list of folder items. The filter option allows you to include and exclude items from the newly inserted source mailbox.
The free trial allows you to test the software's features and functionality. The software demo version allows you to export and save the first 50 items in each folder.
Read More: www.shoviv.com/blog/how-to-migrate-exchange-2010-to-2019-proficiently/
