Dear all.
Would you kindly help me??
When I tried to erase UNUSED DISK SPACE on a USB-connected MO disk (230MB), an error occurred with the following message:
"Failed to create temporary directory to drive X:\, maybe one exists already. Try again"
Failed: X: filename
Failed: X: filename......
As a result, some parts of the MO disk were treated properly, but others were failed: i.e., file slack was remained unerased.
When the disk was treated by other machines (even repeated), the result was the same.
What does the message mean??
What is the cause of the error??
Do you know any solution??
Kind regards,
CAT
PS: OS = WinXP (SP3). Ver of ERASER = 5.7.
Failed: X: filename
Kind regards,
CAT
