FredricJLowe
I installed and ran Eraser 6.0 the other night, It didn't finish. I reviewed some of the forum questions and for Vista it said to Run as Administrator which I did. It completed with errors. Erase then stopped working. I uninstalled and reinstalled and then I was getting memory errors. My 450gb drive that before Eraser had about 330gb free was down to less than 2mb. Dell automatically deleted 3mb. I looked for a folder called Garbage but there was none when I did a search. I then searched for all files since around Jan. 28 and I saw over 1500 that occupied 216mb of space. I sent these to the recycle bin and then rechecked the C drive. Now I have over 330gb of free space. The folder that remains is now empty and is called: C:\WP76EAu!0DU94hR)9m. My question is this the garbage that you referred to in other posts Joel?
One of your replies said to delete system restore. But how do you do that and if you did that, how could you bring your computer back to a previous last known good configuration if something happened to the existing configuration?
I unistalled Eraser and will await your reply as to what to do now. When I reinstall it, and run it to wipe the hard drive free space, when I get the completed with errors what do I need to do?
Will the free space always hog up the hard drive and must I always go back and search for them to delete them if I was to run a eraser wipe hard drive task monthly?
Thank you for your help on this Joel.
