Hello,
I am new to using eraser and would like to know if there is a way I can Stop the "Confirm Erase" window that appears each time I use the shell context menu "Erase" command?
I can't see any choices I checked that might be causing this window to appear.
I thought there might perhaps be a way of shuting it off in the registry.
Thank you for any help or suggestions.
Brad
Brad
