oliver
Importing MBOX files into Hotmail isn’t direct, as Hotmail (Outlook.com) does not support MBOX file uploads. However, you can still do it easily using the right method.
The simplest approach is to use a professional MBOX Converter. You need to add your MBOX files, choose the IMAP option, and enter your Hotmail account credentials. The tool will then transfer your emails directly to your Hotmail account while preserving attachments, metadata, and folder structure. It also supports bulk migration, making it ideal for large mailbox files.
You can use BLR Tools to simplify the process and complete the migration without complications.
A manual method is also possible by configuring your Hotmail account in Thunderbird and importing MBOX files, but it involves multiple steps and takes more time.
Overall, using a converter is the easiest and most reliable way to import MBOX files into Hotmail without data loss.
Read More: Import MBOX to Hotmail Account: Step-by-Step Guide
