I understand that you’re looking for ways to export an Outlook PST file to Exchange Online. There are generally two approaches you can consider: a manual method or a third-party solution. Both options can work effectively, depending on your requirements and technical comfort level.
If you’re specifically interested in using software to upload PST files to Office 365, it’s important to first evaluate your needs. There are many tools available on the market, each offering different features, capabilities, and pricing. Taking the time to research and identify what matters most to you—such as ease of use, speed, security, or bulk migration support—will help you make a better decision.
Based on my knowledge, one option you may consider is the GoldyTools PST to Office 365 Migration Tool. However, I recommend comparing it with other solutions to ensure it aligns well with your specific requirements.
