How do I split a large PST file?
johnsheno
Looking for a solution to split a PST file into smaller parts? I will provide you with a complete and secure way to split them. Try the Softaken PST Splitter Tool, which divides multiple Outlook PST files into small data files at the same time. The application is easy to use and download. It is fully capable of splitting each and every single data item, such as emails, contacts, calendars, notes, tasks, etc.
1. Run the MS Outlook tool and hit the File menu bar.
2. Now, navigate to Account Settings and then click on the Account Settings option.
3. From the displayed dialogue box, click on the Add button under the Data Files tab.
4. Add the name and type PST and click on OK to generate a new Outlook data file.
5. Here, you have to choose File > Open & Export > Import & Export.
6. Select Export to a File and then click the Next button.
7. Choose the folder containing the file you want to export. If you wish to export subfolders, check the Include Subfolders option.
8. Click the Browse button to find a location to save exported files. You may also select the "Do not export duplicate items" option.
9. Finally, press the Finish button to continue.
If you are searching for an effective and reliable solution to split large-sized PST files? Then I would suggest you to use the Outlook PST Splitter tool. It splits the large-sized PST items such as contacts, calendars, journals, etc., This tool supports all versions of Microsoft Outlook and maintained the data integrity throughout the conversion process. The free version of the PST splitter tool splits 25 PST files per folder.
If you want to split large PST file then you can use DRS PST Splitter. It is an excellent software that can break multiple PST file at a time. You can use this tool for both ANSI and UNICODE format. The utility is very simple and can be installed in any version of Windows.
If you want to split large PST files, then you can try the best PST Splitter tool. It creates its own PST split to reduce the possibility of PST files being corrupted due to their size. This utility can separate all MS Outlook items, including emails, folders, contacts, calendars, journals, and more. The software allows a secure and risk-free data split. You can also get a free demo version of the software to evaluate its first 50 emails.
A smart solution to split PST file into smaller parts with Split PST Software. One can easily divide PST file by size, by folder, and by year with this application and create multiple PST files with one big PST file. No Outlook configuration is required to divide PST file with this application. The utility offers desired split goal. Commercial version can install and configure in multiple systems, whereas the individual version can install up to two systems. It splits PST without losing quality. Available Versions- Individual, Commercial.. It doesn’t need advanced technical steps to split a PST file.It is a lightweight application that users can install on their systems without installing MS Outlook. The tool is completely free from viruses
You can opt for the Cigati PST Splitter Tool which is an astonishing utility that ensures high data integrity. Apart from this, it has some advanced features that make it a standalone utility. You can easily split any type of PST file whether it is ANSI or UNICODE PST file. Additionally, it facilitates splitting PST files on the basis of Size, Date, Sender, and Folders. To analyze its amazing performance, you can also try its free demo version.
Ignissta PST splitter and merger software is a reliable and efficient tool for managing large PST files in Microsoft Outlook. The software allows you to split PST files into smaller parts based on various criteria such as date, size, and email folder, making it easier to manage and store. This also helps to reduce the risk of PST file corruption and improves Outlook performance. Furthermore, the software also allows you to merge multiple PST files into a single PST file, making it convenient to manage your mailbox data in a centralized manner. With its user-friendly interface, Ignissta PST splitter and merger software is a must-have tool for anyone who wants to effectively manage their PST files.
Ignissta PST splitter is a software tool that allows you to split a large PST file into smaller, more manageable files. This can be useful if your PST file has grown too large to be easily managed, or if you want to back up or archive a portion of your email data. Our Ignissta PST splitter allows you to easily break down a large PST file into smaller, more manageable chunks. This can be especially useful if your PST file has grown too large to be easily managed, or if you want to back up or archive a portion of your email data.
Ignissta PST Splitter software is that it enables you to split large PST files into smaller, more manageable ones. You can choose to split PST files by date, size, or folder, depending on your specific needs. This can help to improve the performance of Outlook and make it easier to find specific emails or other items that you need. By splitting your PST files, you can also reduce the risk of data loss and ensure that your data is stored safely and securely.
Split large PST files with the most efficient and safest application. Try the ToolsCrunch Split PST Tool Mac, which can be used to simply split a huge PST file into smaller portions. Outlook PST files are swiftly and simply extracted, preserving all data. Both non-technical and technical users will find it beneficial, and it is rather easy to use. Outlook PST files can be sorted by year, folder, and size. Outlook PST files are simply saved to a computer by the user. It works with every version of Windows OS, including 11, 10, 8.1, 8, 7, Vista, and XP, and every version of Microsoft Outlook. It splits PST files for Outlook without using Outlook. Test versions are available for free to users.
Split a large PST file with an expert solution. Try the ToolsBaer Split PST Tool, you can partition large amounts of Outlook PST duplicate data by size, year, and folder. As per the user's instruction, it splits Outlook PST files into appropriate sizes, years, and folders. It is also compatible with every version of Windows OS including 11, 10, 8.1, 8, Vista, and XP. Moreover, free trial versions are offered. All versions of Microsoft Outlook, including those from 2021, 2019, 2016, 2013, 2010, 2009, 2007, 2003, and 2000, are supported. Outlook PST files in ANSI and Unicode are also supported.
Shoviv PST Splitter Software is an excellent solution for splitting large PST files. It’s a user-friendly tool for all skill levels users, and it ensures that all your data, such as emails, contacts, and calendars, remains as it is in resultant files. It works with all versions of the PST files, whether you have ANSI or Unicode types PST files. It also allows you to add multiple files for splitting at once, saving you time and effort, and it works with all versions of Windows OS. If you’re dealing with large Outlook data files, the Shoviv Tool can help you to split PST file without losing any vital information.
Read More: Split PST files into smaller parts
For splitting large PST file, i recommend the GainTool Split SPT Tool which is easy method to break heavy PST files into smaller parts. Users can select the option to splits PST files in three different ways: size, folders, and years. It maintains the original PST database files while splitting PST files into multiple file formats, supports ANSI and UNICODE files. The software able to works with Windows OS versions such as 11, 10, 8.1, 8, 7, XP, Vista and MS Outlook versions including 2021, 2019, 2016, 2013, 2010, etc. To test the software, use the free demo version.
