vames
Transferring MBOX emails to DOC format is a simple way to save email content as readable documents. One common method is to open the MBOX file in Mozilla Thunderbird, copy the email text, and paste it into Microsoft Word. After that, you can save the file in DOC format for easy access and sharing.
From my experience, this works well when you only need to convert a few emails. But if you’re handling large MBOX files or multiple folders, doing everything manually can take a lot of time.
For bulk conversion, the BLR MBOX Converter Tool offers a much easier option by allowing multiple MBOX emails to be transferred into DOC format at once while keeping the content properly organized.
Additionally, using an mbox to pst converter can be useful if you later need to migrate your mailbox data to another platform or format.
So, while manual conversion is fine for smaller tasks, dedicated tools are usually the better choice for large-scale MBOX to DOC conversion.
