How to Analyze Outlook PST Files Using a Forensic PST Viewer
Anshu_123
When dealing with email investigations, legal audits, or data analysis, Outlook PST files often contain critical information. A Forensic PST Viewer helps you examine PST files in a structured, read-only manner without altering the original data.
TL;DR: To analyze Outlook PST files, use a forensic PST viewer that allows secure, read-only access, metadata inspection, and advanced search features. A reliable third-party option is Cigati PST Viewer, which helps users view and examine PST data efficiently without modifying the original file.
Why Use a Forensic PST Viewer?​
A forensic viewer is useful for:
  • Reviewing emails, attachments, contacts, and calendars
  • Analyzing metadata such as sender, recipient, timestamps, and headers
  • Searching specific keywords for investigation purposes
  • Accessing corrupted or inaccessible PST files
  • Maintaining data integrity in a read-only environment
This approach ensures that the original file remains unchanged, which is essential for compliance and forensic analysis.
Steps to Analyze PST Files​
  1. Launch the Forensic PST Viewer Tool
    Install and open the utility on your system.
  2. Load the PST File
    Use the “Browse” option to add the required PST file.
  3. Preview Data
    The tool will display emails and related mailbox items in a structured format.
  4. Use Search & Filter Options
    Apply filters or keyword searches to quickly locate specific data.
  5. Analyze Metadata
    Review email headers, properties, and attachments for detailed examination.
Recommended Third-Party Tool​
For reliable and efficient PST analysis, you can consider Cigati PST Viewer.
It is designed to:
  • Open and view PST files without Outlook
  • Support corrupted or large PST files
  • Provide advanced search and preview options
  • Maintain data integrity in a secure, read-only mode.
