How to Backup Thunderbird Emails Locally/External Drive?
To backup Thunderbird emails locally or to an external drive, users can manually copy their Thunderbird profile folder, which contains all emails, settings, and attachments. First, open Thunderbird and note the profile location by navigating to Help > More Troubleshooting Information and checking the Profile Folder section. Close Thunderbird, then go to the specified directory (usually found in C:\Users\YourUsername\AppData\Roaming\Thunderbird\Profiles\). Copy the entire profile folder and paste it into your desired backup location, such as an external hard drive or another local directory. Alternatively, users can export emails individually as EML files by dragging them into a folder on their system. While this method works, it can be time-consuming and requires manual updates for future backups.
For a more efficient and automated solution, the DRS Softech Thunderbird Backup Tool simplifies the process by allowing users to back up their Thunderbird emails in multiple formats, including PST, MBOX, EML, PDF, and more. It preserves folder hierarchy and metadata while offering advanced filtering options. This tool eliminates the need for manual copying and ensures that backups are regularly updated without hassle. If you need a reliable and effortless way to secure your Thunderbird emails, the DRS Thunderbird Backup Tool is an excellent choice.
Are you trying to find an easy-to-follow guide on backing up Thunderbird emails? Try the BLR MBOX Converter Tool if that's the case. This utility makes the process easier by enabling users to backup their Thunderbird emails in a variety of file types, such as PST, MBOX, EML, PDF, and more. It provides sophisticated filtering options and preserves information and folder hierarchy. This solution makes it unnecessary to copy files by hand and guarantees hassle-free backup updates regularly.
Main Features of this BLR MBOX Converter Software:
  • Bulk Conversion.
  • Effortless and safe conversion or backup.
  • Working with all Windows OS.
  • No need for technical expertise.
  • Simple Graphical users interface.
