Migrating data from EDB to PST using a manual method can be a complicated task as the method is lengthy.
You may misplace your data furthermore. So, I suggest using eSoftTools EDB to PST converter tool for effortless EDB to PST conversion.
It has many brilliant features and provides a hassle-free way for EDB to PST conversion.
eSoftTools Converter for EDB extracts and migrates offline or online EDB to Outlook. This application supports working with almost all the Outlook and Windows editions - Outlook 2016 to 2013 and operates in 32bit and 64bit. It finances all latest released versions of Windows OS like Windows 10 to earlier to Win-8-7-XP-Vista
• Initially, you need to download eSoftTools this tool from its website, and then install it. Launch the tool and on the screen, you would find an option to add offline EDB files as a source.
• Select the source type and click Next
• Then, it yields a quick preview of your entire EDB file data so that you can esteem your items before migration.
• Now, right-click on the folder and select Export mailboxes to PST files.
• Choose the filter options as per your need; provide a saving path and move Next. Your EDB files are successfully converted to Outlook PST.
Get More Details:- convert EDB to PST in outlook 2013
