daevenlate
With the help of InQuit EDB to PST Converter application you can convert single as well as multiple EDB files without any problem. It is designed with the best technology and the best algorithm. During the conversion process it never make any changes in the database and provide you an accurate result that is better than your expectations.
Before finishing the conversion process it will show the preview of the recovered mailbox and provide the best solutions as per your problem. To operate this tool there is no need of any technical knowledge and skills. At the same time you can migrate single as well as multiple EDB files with simple steps.
The users can migrate their data into PST, EML, EMLX, MSG, vCal, vCard, and MBOX file format. Apart from PST, you can migrate the data into cloud-based application Office365 & Live Exchange Server that is an additional and best feature of this tool. It has auto scanning feature that automatically scan the data of EDB file and then migrate the data of EDB file into Outlook PST.
Using it you can also export pub1edb and priv1edb file along with email, notes, contact and many more. The free demo version give permission to export 30 emails per folder free of cost.
Read More: Exchange EDB to PST Converter
