How to Convert OST to PST Without Outlook? Smart Solution
If you're looking to convert an OST file to PST format without any risk of data loss, GoldyTools OST to PST Conversion Tool is the perfect solution. This tool offers an instant and reliable way to migrate your OST files to Outlook PST format. It preserves all essential OST file properties, including Inbox, Outbox, Sent Mail, Notes, Tasks, Journals, Drafts, and more.
Compatible with both Windows and macOS, this application ensures seamless conversion across all versions of both operating systems.
To convert OST to PST without Outlook dose not possible. You need a third-party OST to PST converter tool since Outlook does not provide a direct way to open OST files. Reliable tools like OSTtoPSTAPP OST to PST converter tool. It can help you extract and convert OST files without requiring Outlook. Simply install the software, add the OST file, scan it, preview the data, and save it as a PST file. This method is a safe and quick conversion of emails, contacts, calendars, and attachments without Outlook. Always use a trusted tool to maintain data integrity and prevent corruption. It also supports Outlook 2019, 2016, 2013, and other versions.
To manually convert an OST file to a PST file, begin by opening Microsoft Outlook. Go to "File" > "Open & Export" > "Import/Export." Select "Export to a file," opt for "Outlook Data File (.pst)," and then choose the OST file you want to export.
Another option is to use the Sysinfo OST to PST Converter, a dependable and powerful tool specifically designed to transform OST files into Outlook PST files with 100% accuracy and no loss of data. This flexible software not only performs OST to PST conversions but also supports additional formats like MBOX, PDF, JSON, and others. It guarantees a seamless conversion process while keeping your data intact.
