If you want to convert Thunderbird data to Outlook PST format in a quick and easy method, you may use the eSoftTools Thunderbird to Outlook Converter Tool, which can swiftly input numerous MBOX files or formats and export them to Outlook PST. It also provides a free sample edition that allows you to convert the first 25 Thunderbird emails to Outlook for free.
For more info- Convert Thunderbird to PST files
