How to disable logfile and activate auto-reboot for PXE-boot
steno
Hi,
I'm using an autonuke DBAN's-bootdiskimage via PXE-boot. How can I disable the writing of the logfile and initiate a reboot, after the harddisks are nuked :?:
(the system hangs after the nuke because the logfile can't be written)
You must customize the rc file in the initrd file and repack DBAN.
Note that pxelinux is usually a better choice than pxeboot.
rekyt1
Remove writing to log file and auto reboot. Has anyone done this yet and repacked DBAN?
I get the error that the log file can't not be written since there is no floppy present. I am not using a floppy and do not want a log file to be written.
Thanks in advance!
