While many free tools are available in the market, they often come with limitations such as incomplete data migration, file size restrictions, slow performance, or compatibility issues. In such cases, GoldyTools OST to PST Converter can be a reliable and secure alternative.
This software is designed to accurately export all mailbox data, including emails, contacts, calendars, notes, messages, and attachments, without altering the original data structure. It supports conversion from corrupted, orphaned, or inaccessible OST files into PST format with high accuracy.
The tool works smoothly on both older and newer Windows versions, including Windows XP, Windows Vista, Windows 7, Windows 8, and Windows 10. It also supports multiple versions of Microsoft Outlook, including Outlook 2003, 2007, 2010, 2013, 2016, and 2019.
One of its advantages is that it is a standalone utility, meaning users do not need to install Outlook separately to perform the conversion process. The software also offers an easy-to-use interface, making it suitable for both technical and non-technical users.
However, users should keep in mind that GoldyTools OST to PST Converter is a paid solution. Since several OST to PST converter tools are available in the market, it is always recommended to compare features, pricing, recovery capabilities, and compatibility before selecting the software that best fits your requirements.
