How to Export Emails from G Suite to Excel File?
Aloraeve
With the Advik Google Workspace Backup Tool, you can effortlessly save your important data. This tool allows you to export G Suite emails to CSV, EML, PDF, and various other formats. Thanks to its simple and user-friendly interface, you can complete the backup process smoothly without any complications.
Steps to Export G Suite Emails to Excel File -
  1. Launch the Advik Google Workspace Backup Tool.
  2. Log in with your G Suite credentials.
  3. Select the email folders you wish to export.
  4. Choose CSV or any other preferred file format from the available options.
  5. Specify the destination folder and click the Backup button.
That's it! Your G Suite emails are successfully exported.
