If you want to Export Mails from thunderbird to outlook MSG then you should use eSoftTools Thunderbird to Outlook Converter Tool. this tool is the best converter tool as compared to other companies' softwares and also it has a free demo version of the software in which every single user can export their 25 items from each Thunderbird Mails without spending any cost on it. If you want to buy the software then go with the link given below.
Read More:- Export Mails from Thunderbird to Outlook MSG
