How to export Thunderbird to Outlook?
If you want to export Thunderbird to Outlook, then just go on Google and search for eSoftTools Thunderbird to Outlook Converter software. You can easily download this software from its official website. It has the capacity to export individual or even multiple Thunderbird MBOX files to Outlook PST, Office 365, EML, EMLX, Yahoo, MSG, GMAIL, and HTML files. It can also work together with all versions of MS Outlook 2019, 2016, 2013, 2010, 2007, & 2003.
For more info:- Export Thunderbird to Outlook
Using automated tool Softaken MBOX to PST Converter Software to convert MBOX to Outlook is the most effective approach. This software shows all MBOX mailbox items on the screen and allows users to pick the items they want to convert while leaving the rest intact. Users can download the free trial versions to give it a try for free. There are various conversion option such as- MSG, EML, OFFICE 365, EMLX, etc.
MBOX to PST Converter is the best software for converting MBOX files to PST and other file formats without losing data. MBOX emails and attachments are exported using this feature. Bulk conversion is possible, which saves time. Depending on your needs, you can save MBOX files with different file names. It has a search feature that makes it simple to find certain MBOX files. The software also comes with a free trial version. Using this, you can preview the MBOX files and save the first 10 items per folder.
