kimwilson
Hey..!! Do you want to import MBOX file to Gmail, follow these methods:
Method 1: Using Mozilla Thunderbird (Free Method)
Steps to Use Third-party tool:-
- Install Thunderbird and add the "ImportExportTools NG" add-on.
- Import the MBOX file into Thunderbird.
- Configure Gmail via IMAP in Thunderbird.
- Drag and drop MBOX emails into the Gmail folder.
- If your MBOX file is from Google Takeout, use Thunderbird or an MBOX viewer to read the emails and manually forward important ones to Gmail.
- Download the BLR MBOX Converter Tool.
- Start the software and select the MBOX files.
- Preview files and select Gmail.
- Log in to the account by using the ID and password.
- Click the Convert button to begin the conversion process.
