How to Import Zimbra TGZ to Thunderbird MBOX (Easy Method)
Anshu_123
If you’re moving emails from Zimbra to Mozilla Thunderbird, you can’t import TGZ files directly because Thunderbird only supports MBOX format. So first, you’ll need to convert your Zimbra TGZ backups into MBOX before importing them.
Manual Way (Not Recommended for Large Data)
There’s no direct manual import from TGZ to Thunderbird. The only workaround is:
  • Restore the TGZ backup to a Zimbra account
  • Add that Zimbra account to Mozilla Thunderbird via IMAP
  • Let Thunderbird sync all folders
This method is slow, depends on a live Zimbra server, and can be unreliable for big mailboxes.
Use Cigati Zimbra Mail Converter
To save time and avoid server dependency, I used Cigati Zimbra Mail Converter to convert TGZ files straight into MBOX format that Thunderbird can import.
What it does well:
  • Converts Zimbra TGZ → MBOX for Thunderbird
  • Keeps folder structure & email metadata
  • Supports batch conversion
  • Preserves attachments & formatting
  • Works offline (no Zimbra/Thunderbird required)
  • Simple UI for non-tech users
Steps to Convert Zimbra TGZ to MBOX
  • Install Cigati Zimbra Mail Converter on Windows
  • Add Zimbra TGZ file(s)
  • Preview mailboxes (optional)
  • Choose MBOX as output format
  • Pick destination folder
  • Start conversion
  • Import the MBOX files into Mozilla Thunderbird
You can’t import TGZ into Thunderbird directly. Either sync via IMAP from a live Zimbra server (slow + risky) or convert TGZ → MBOX using a dedicated tool and import cleanly into Thunderbird.
There is no manual way to Import Zimbra TGZ to thunderbird MBOX, We also suggest you best and easy methods to successfully Migrate Zimbra TGZ files to Thunderbird MBOX format by using KDETools Zimbra to MBOX Converter tool.
Zimbra to MBOX Converter tool also provide you FREE demo facilities to Convert first 30 items from ZImbra TGZ to MBOX format with easy methods. Download Free: https://www.kdetools.com/zimbra/mbox/
Follow Easy Steps to Convert Zimbra to MBOX Thunderbird
  • Download and Run Install KDETools Zimbra Converter on Windows
  • Click on Browse button to "Add Single or Multiple Zimbra TGZ file(s)
  • Auto start scanning process and showing Preview mailboxes (optional)
  • Click on Export button to Select/Choose MBOX as output format
  • Browse the destination folder to Save MBOX location
  • click on convert now button to Start conversion
