BeverlyGarcia
When manual methods fail to merge PST files due to size limitations or Outlook compatibility issues, using GainTools Merge PST Tool is a reliable solution. The software allows you to merge multiple PST files into a single PST file without data loss. It maintains the folder organization, email formatting, attachments, contacts, and calendars. It accepts ANSI and Unicode PST files and offers numerous merge options including merging selected folders only. Automated PST merge tools are preferred by many users as manual import/export procedures are usually time consuming and can lead to Outlook problems. The program works seamlessly on recent Windows OS versions and makes handling large PST files easy for both expert and non-technical users.
