How to Repair and Import PST files into EML, and MSG?
alex786
If your PST file gets corrupted and you want to repair them, the effective way is to import them in other file formats. So, import PST file into EML, and MSG format after repairing the corrupted PST file. Shoviv offers advanced software to execute this task without a single error. Shoviv Outlook PST Repair Tool effectively repairs corrupted and inaccessible PST files and allows users to save them in various file formats like EML, MSG, HTML, RTF, etc.
Moreover, there are no restrictions on adding multiple PST files and their size. This software expertly maintains the folder hierarchy and integrity of the data. It also provides a preview option to the users, which helps them to cross-check the added PST files before processing the tasks. This software has a search through which users can find the desired items by adding a specific field name.
A free demo version of this software is also available for users to download.
Know More: www.shoviv.com/blog/convert-pst-to-eml-file-accurately/
I can understand your problem, If you are really facing problem to transfer PST files into EML format then I will suggest you the most useful software Softaken PST to EML Converter that easily converts your all PST data into Windows Live Mail files format. This tool is a perfect tool that will easily transfer your large-sized PST file to EML format. This app supports all MS outlook versions includes 2000, 2003, 2007, 2010, 2013, 2016, 2019 and below version.
barry-kag
To access the database of PST file without Outlook simply utilize this application called PST to EML Converter Software. It comes with a preview facility by which users get the feature to see a live preview of all inner elements of the PST file. This tool also supports working as an PST file repair tool to recover lost mailbox items from corrupt PST file. You can easily export all emails, attachments etc to EML, EMLX, MBOX, various other file formats.
