RandomNick
Hello. I'm running 6.0.6.1376 on an up to date XP Pro machine. When I utilize Eraser via the shell (Right Click Folder->Eraser->Erase)...
1) Process starts and a taskbar notification area icon appears
2) A "New Task added..." notification tip is displayed
3) A "Task completed..." notification tip is displayed
4) The process remains running in the background and the icon remains visible in the notification area
Is it possible to configure the program so that it fully exits when it has successfully completed its task? Currently, it appears that one must right click the notification icon and select exit in order to terminate the program. Note: when I do that, the icon remains visible in the notification area until I mouse over it. FWIW, I have Taskbar Notification Area "Hide inactive icons" disabled. Perhaps the program isn't doing something it needs to do in order to update the notification area and make the icon automatically disappear when it should?
Thanks for any help you can provide.
