Hello. My old laptop died, but I was able to access the old hard drive via docking cables. I need to return the dead laptop and its hard drive to the manufacturer for replacement, but I would like to remove traces of my banking and purchases, etc. As a novice, I am concerned about jeopardizing my present laptop in using Eraser.
If I download Eraser, is there a risk of its wiping out my present laptop hard drive? I see from the instructions that you can select the drive, so I assume it should not be harmful, but I want to be utterly sure. Also, once I have wiped the old hard drive, how do I uninstall Eraser from my good laptop?
Thanks in advance.
Thanks in advance.
