I have a problem with using the Eraser program, a short description below.
System Windows 8.1 pro.
Ciphered HDD BITLOCKER , PC with TPM module or without the module
System accounts:
Admin - used sparesly for administration purposes
User - on rules of standard user
Point was to fund a way to completely remove the content of an SD memory or some files, I chose the Eraser program.
However I have experienced a few problems:
1. Eraser always requires admin password - is there a possibility for the program not to require the password?
2. If the PC has TPM module and system HDD ciphered with BITLOCKER, file removal works without problems, however there's still an issue of requireiment of admin password.
3. If the PC has no TPM module and BITLOCKER cipher is enabled system drive in Windows 8.1 Pro, file removal from SD drive or system drive always finishes without erasing information from the program, never adds itself to the task list of the Eraser program and never reports any errors.
Files are not being removed!
I require assistance with this problem or information that you cannot use this program in such konfiguration with such security systems.
With best regards,
Michal
System accounts:
With best regards,
Michal
