Techno phobia
Hello!
I posted a topic in the eraser support forum about 1/2 months ago titled, a simple guide to erasing internet content with eraser.
http://www.cipherserver.com/phpbb2/view ... 77c9c53b34
In that thread people told me use spybot to shred usage tracks and eraser to erase unused disc space. Anyway, at first I was a little unsure as to how well this get's rid of all content, so I was told by others in the thread that my best bet would just be to completely erase the entire drive and reinstall- I've been told that DBAN is the best program to use. I'm quite worried about doing this because I know I need to back-up any data I need to keep, and I'm not brilliant with computer's so need a couple of questions answered if possible.
I went on another forum to ask about this but their instructions weren't very clear, so I decided to come and annoy everyone on here againwith my boring questions!
1. If I use DBAN, how many passes would I need to use in order to insure that it's almost impossible for a data recovery centre or PC shop
to not find it?? (or just a great PC person with lots of money)?
2. When you place the CD-RW or CD-R in to make your disc it says `boot up` the disc, what does that mean and how do you do it??
3. I need to create a clone of my current drive just incase anything goes wrong, I'm well aware that it would bring back my history if I had to reinstall the original drive, but if the worst came to the worst I'd have to. So my questions about it are:
a. What's the best free ghosting program you know of and which website can you get it from??
b. Where abouts on the drive do you store it?
c. If I have to reinstall the old drive how do I do it??
4. I need to back up my norton antivirus program + it's reg keys, configuration and as well as the program its self - basically anything and everything that I need in order to use the program.
a. Is there any programs out there which can show you where the reg keys, configuration, original downloaded file are located for norton, or would I need to find them manually, if so can someone tell me where I'm most likely to find them?? I also need to back up games, the my music folder, my documents, my hp printer and all its confi and reg keys.
b. What should I save the mymusic, my documents, games to a floppy disc or will I need to save to cds/dvds??
c. If I'm saving a game for instance would I just go to the root of where it is saved (D:/Documents and settings for instance0 and right click- send to- floppy.
That's all for now- sorry to be a pain! I think I have a few more questions but I can't remember all of them right now so will come back hen my first lot have been answered!
