Identify partitions
Hi,
I have a disc with three partitions. To try dban I created a fourth 2gb partition. This showed up as the second partition in Partition magic. Dban
zapped the last partition on the drive. Is there a way to identify partitions by size or any other way?
Regards,
GL
Anonymous0
Try PartitionInfo, this tool should be included with Powerquest PartitionMagic.
If there are no MBR errors, it will show you the order of your partitions.
