Hello David and everyone else,
I see this topic is quite old but it would be great to finish what was started.
To clarify, I've read the "common-eraser-questions-read-this-before-posting" topic and the "getting-to-know-eraser-6.6354" topic.
In short, I would like to delete some sensitive files from a laptop. To answer your (David's) questions from above (which the original poster left unanswered):
1) I am using Windows 8.1 and Eraser 6.2.0.2969
2) The laptop has both an HDD and an SSD. The files I want to delete are on the HDD
3) System Restore was enabled for the partition on which the files in question were stored. I went to System Protection for that partition and deleted the existing restore points. For Volume Shadow Copying (or specifically, File History since it's a Windows 8), this was already turned off.
Steps I took:
- deleted the restore points for the HDD partition where the files in question were located
- right-clicked on the files that I want to overwrite and "Erased" these files using Eraser
- I am about to initiate a wipe of all the free space on the HDD
Issues:
- my core partition is C. That's where Windows etc are installed. If I deleted (using the superficial right-click "delete" option) some non-core files from C, then I ran the "Erase Free Space" option on the entire HDD, did this also erase the free space in C (considering this is the core system partition) including the space where the aforementioned deleted non-core files used to be?
- is it possible for files to have been moved from the laptop's HDD to its SSD automatically/ without a user directing it?
- I saw you mentioned that copies of overwritten files may exist on "the paging file". What can be done about this?
- aside from the above, are there any other steps I need to take in order to make the target files irrecoverable?
- when using Eraser to permanently delete files on an SSD (by overwriting the entire SSD, are HPAs (or anything else) an issue that I should be aware of? That is, is it possible that some of the data on the SSD remains untouched by Eraser because that data is in an HPA?
I will do a test using file recovery software shortly, but first I wanted to hear your thoughts on whether anything else should be done to ensure the files in question are gone for good.
Thank you,
