Hi there. Can someone here explain why Eraser states that a file is "locked by another process" when there are no other obvious programs or processes that would be using the file?
This happens on occasion, also with Eraser 5.7 as well, and happens with any file - not just ones that are obvious to being in use, such as temporary files for example. Sometimes opening the file and closing it works, but other times it doesn't, in which case the only solution I can see to this problem is to reboot, and is a pain in the neck.
For example, just now I am trying to erase a movie file approx. 500 MB in size using the explorer shell. Yet the program says that the file is in use by another process. However, no other programs seem to be using the file, such as a movie player for example. I checked the task manager, but all I see are processes which are required for the OS to function properly as follows:
crss.exe
explorer.exe
lsass.exe
services.exe
smss.exe
svchost.exe (listed 3 times, each with a different amount of memory usage)
System
System Idle Process
taskmgr.exe (obviously is shown when Task Manager is running)
winlogon.exe
Would one of these processes work with the file for some reason? Why would Eraser state that a file is in use when it doesn't appear obvious that any program or process is using the file?
Any information that can be provided is appreciated.
- Jabba
crss.exe
explorer.exe
lsass.exe
services.exe
smss.exe
System
System Idle Process
winlogon.exe
- Jabba
