Is it possible to convert PST files into RTF format easily?
vames
Yes, it is possible to convert PST files into RTF format, and the process is easier than many users expect. I also needed to do this while working with old Microsoft Outlook emails, especially when I wanted to preserve email formatting in a document-friendly format. At first, I assumed Outlook would directly convert entire PST files into RTF, but the process is usually done email by email or with the help of a PST file converter.
One manual method is to open the PST file in Outlook, open a specific email, and then use the Save As option to save the message in Rich Text Format (RTF). This works well for a small number of emails, but it becomes repetitive and time-consuming when dealing with large amounts of mailbox data.
Because of this limitation, many users prefer BLR PST Converter for bulk conversion tasks. A reliable PST file converter can help convert multiple PST emails into RTF format while preserving formatting, attachments, metadata, and folder structure accurately.
If you want to export PST file to RTF or any other file format like EML, MBOX, PDF etc. then try MailsDaddy PST file converter tool. This single GUI tool has several features and export options to load and export data into RTF file format. The software is designed on simple GUI interface so each level of user can easily use the solution and migrate emails from PST to RTF file format.
The application automatically preserves folders, subfolders, header, meta properties etc. during the whole conversion. You can also try the free demo edition of the solution. It is compatible with all Windows OS of 32 and 64 bits.
