Is there a quick way to turn MBOX files into Maildir?
vames
Yes, there is a quick way to turn MBOX files into Maildir.
One manual method is to use an email client like Mozilla Thunderbird or another Maildir-supported mail system. First, import the MBOX file so the emails are visible, then move or export them into a Maildir-based setup where each email is stored as a separate file. This works, but it can take time and may feel technical if you are handling large amounts of mailbox data.
For a faster and easier option, many users prefer using the MBOX to PST Converter. It helps manage MBOX mailbox data and makes the conversion process smoother while keeping emails, attachments, and folder structure properly organized.
So, while manual methods exist, using a tool is usually the quickest way to convert MBOX files into Maildir.
