Howdy,
I've installed Kaspersky 5.0.227 Personal a few days ago. Since them, Eraser isn't working reliably. Mostly it isn't able to wipe the choosen files and gives me only an error report:
In English it means something like "The task wasn't able to access the file, because it is locked by another task.".
With Kaspersky 5.0.142 Personal I had not this problem and all worked fine. A possible solution could be a Kaspersky downgrade or a temporarily deactivation of the on-access module.
I would ask, if this could be an Eraser bug too or is it a Kaspersky problem?!?
Der Prozess kann nicht auf die Datei zugreifen, da sie von einem anderen Prozess verwendet wird.
