Laurawilliams
To convert the data of NSF file into Outlook PST file format choose the Lotus Notes to PST Converter. It is designed by using the rich algorithm and the best technology. It supports Microsoft Outlook 2019, 2016, 2013 and all below versions and the preview option which allows you to see the results before final conversion.
Using it you can also export your large file into Outlook PST. It supports OS Windows’s version 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit) as well as Exchange Server version such as 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016. It provide one of the best facility in the market.
After the conversion task users can save their data into several file formats such as PST, EML, EMLX, MSG, CSV, HTML, vCal, vCard, MBOX for future use. Before finishing the conversion task of NSF file to PST file it shows the preview of recovered mailbox along with email, draft, task, attachment, notes, calendar, inbox (To, Cc, From, Bcc, Subject, Object, Time and Date).
This software provides a free demo version to convert 25 emails per folder free of cost. If you are not happy with this application then you can return it under 30 days.
Read More Info: Convert Lotus Notes to Outlook PST file
Free Download Software with Cnet:https://download.cnet.com/ATS-Notes-Converter/3000-2369_4-77530262.html
