How low-level do you need? If you are saying enough to destroy the file system structures, Eraser 6.0 cannot do it but Eraser 6.2 (experimental) can. 6.2 can go so far as to destroy your boot record.
If you want to do a manufacturer's format, then I think you're out of luck; only manufacturers can do that (hence the name...)
