making floppy
How do you make a floppy, I download then open up folder hit install brings up does then from there it doesnt work. I did make a floppy likre that then it didnt do anything wouldnt load.[/b]
wert said:
How do you make a floppy, I download then open up folder hit install brings up does then from there it doesnt work. I did make a floppy likre that then it didnt do anything wouldnt load I can not figure out for the life of me how to make a workable floppy. I have windows XP
Gralfus
1. Download the zip file
2. Unzip the file to your hard drive
3. Put a blank floppy disk into your floppy drive
4. Double-click the Install.bat file
5. Press a key like (Enter or the spacebar) to start the installation
6. When it is finished, it will tell you to press a key to close the install screen
Now your floppy is ready to use as a boot 'n nuke disk.
