mithileshtata
Migrating from SharePoint On-Premise to Office 365 using the Aryson Office 365 Migration Tool is a streamlined process designed to handle data, permissions, and site structures.
Here is the condensed workflow for the migration:
1. Prerequisites & Setup
- Permissions: Ensure you have Global Admin credentials for the destination Office 365 tenant and Farm Admin rights for the source SharePoint environment.
- Installation: Download and launch the Aryson Office 365 Migration Tool on a machine with access to your SharePoint server.
2. Connection Phase
- Source Connection: Select SharePoint as the source. Enter your Site URL and credentials to load the site hierarchy.
- Destination Connection: Choose Office 365 as the destination. Log in using your admin credentials to establish the link.
3. Selection and Mapping
- Select Data: From the tree view, check the specific Site Collections, Subsites, or Document Libraries you wish to migrate.
- Mapping: Map the source site to the corresponding destination site in Office 365. The tool typically allows for automated mapping based on names.
4. Filters and Configuration
- Date Filters: Use the filter settings to migrate only items created or modified within a specific timeframe.
- Item Selection: Choose whether to include Permissions, Subsites, and Versions.
- Advanced Settings: Configure how to handle duplicate items or naming conflicts.
5. Execution and Verification
- Start Migration: Click the Convert or Migrate button to begin the data transfer.
- Monitor: Track progress through the live status bar provided by the interface.
- Reporting: Once finished, download the Log Report to verify that all items migrated successfully and check for any failed transfers.
