Joel,
So far with the new stable version 6, it seems to be working pretty good.
System is
Vista 64 Business
8GB RAM
Eraser 6.0.6.1376
I did have one crash when I used the context menu to erase the recycle bin. Also, when exiting Eraser from the tray bar it does end the process but the icon remains as if the program had crashed. It disappears when one hovers the mouse over it.
I was wondering, is it possible to keep the checkbox options for the settings, as in version 5 to delete clusters, erase the MFT etc? Also, it would be nice to have that feedback when erasing the recycle bin. Sometimes I delete large files and it would be good to monitor progress and results as in version 5.
I can confirm that deletion of the files in the MFT for a FAT32 external driver worked flawlessly. Recuva is finding ZERO files after erasing the table!
Finally, unlike some other unappreciative jerks I've see on here lately, I do appreciate very much that you are handling all this on your own without compensation. I find it extremely rude that some would make demands and harass you for a program that is not perfect, while they are contributing nothing. I wish people would grow up and offer a thanks for a doing a very difficult job on your own time for the benefit of the community. Cheers Joel!
System is
Vista 64 Business
8GB RAM
Eraser 6.0.6.1376
