Hello, I,m afraid as much time as i spend with the PC i'm unfamiliar with the most basic of features of a WINDOWS98 O/S. I've downloaded the Eraser.zip but before i run the set-up i need to catch up on a thing or two first. QUESTIONS: (1) Where can i find the settings for the Swap File(under virtual memory?)
(2) Is there a freeware program i can use to see the results after a wipe?
(3) I won,t be exercising the Task Schedule feature at all, is this included in the setup or can i omit the file that would be used for this purpose.
(4) After reading some posts here i,ve determined ERASER should be pretty safe to use, are there any serious issues that i should be concerned with?
(5) How often can a Disc be overwritten before it begins to lose some of its performance properties?
Thanks for any and all of your answers and i apologize for the lack of the basics but i appreciate the assisstance nonetheless.
