Need to know in close steps how to use DBAN and to reinstall
Alright, I am not much of a computer knowlegable man, but I do know some aspects. Well here goes, I want to use DBAN because I have had this computer for over four years now. My computer stats are:
550 mhz AMD K7
96 mb ram
20 gig hardrive
Windows 98 S/E
Nvidia TnT2 M64 32 mb
Sony CD-RW CRX100E
Hitachi DVD-rom GD-2500
If I wanted to use DBAN how can I reinstall windows 98 SE with all my hardware still in tact without touching my BIOS? And how long will it take to do a full deleting off the hard drive? Thanks! If any questions about my hard drive please post and I will answer.
ueivar
If you use DBAN and choose to do a "quick erase" of the whole disk it could take about an hour or more - depending on the mother board and your hard drive.
After that you need the Win 98 SE CD + all extra drivers that might not be on the CD (audio, video etc.) to do the reinstall.
It shouldn't be a big problem to get your PC up again..
Note that the point of DBAN is to overwrite every possible spot on a disk, so that the data that was previously stored there is no longer available. On your hard drive, there is a "table of contents" so to speak, which tells where on the disk each file is found. For example, this table might say that file "mystuff.txt" is stored in locations #7845-#7849. When you delete mystuff.txt in Windows, the table of contents is updated to show that locations #7845-#7849 do not contain data (new data can be written there). Even though those locations are marked as available for writing, the actual locations still contain whatever data they had before. Even though Windows thinks the file is gone, the 1's and 0's that made up the data are still stored on the disk.
Along the same lines, FDISK will delete the "table of contents" for the whole disk structure. All your partitions will be gone, and you will be starting fresh from a "clean" disk. But again, the data is still there, the space is just marked as being available to be written.
DBAN overwrites all this "available" space (actually ALL disk space) with garbage. None of the remnants of your data will remain on the disk afterwards. It is used when disposing of a drive, so that none of the old data can be recovered by someone else.
If you plan to still use the computer, you might as well just format or fdisk the drive. This will give you a "clean" drive to start your install from. The remnants of your old data will still be on the drive, but they'll be overwritten by the new Windows installation and anything else that gets written to the disk. Reusing the disk does the same thing as DBAN - it overwrites the data remnants with other data. The only difference is that your new data may be stuff you don't want left on your disk (so when you really want to get rid of the drive, you'll need to use DBAN), while DBAN fills it with meaningless garbage.
Reinstalling Windows after DBAN (or a format/fdisk) is exactly the same as installing it on a brand new hard drive. You'll have to set up the file system (NT-based Windows versions let you do that as part of setup after booting off the CD), install Windows and any needed drivers (like ueivar said), and your programs and any data you backed up. DBAN (and format/fdisk) doesn't have anything to do with your BIOS, but you may want to change the settings in your BIOS to boot off the Windows CD before booting off the hard drive, just to make the install easier.
To sum all that up, DBAN doesn't affect anything about the way your computer or disk work. DBAN simply overwrites possible data remnants with garbage so that your old data can't be recovered. Note that overwriting all the programs and data on your disk with garbage (using DBAN or otherwise) will affect your ability to use your computer though. =)
InvisiBill
www.invisibill.net
