Outlook PST split tool
split tool allow you to split your PST file in five different ways,Split PST by Date, Split PST by Size, Split by Folder, Split by Sender’s Email ID, and Create separate PST for every selected folder.ou just need to provide the password of the PST file in the tool and follow along.
  • Prevents corruption due to over-sized PST file
  • Splits password-protected PST file without disturbing the integrity of original data
  • Support MS Outlook Office 2019, 2016, 2013, 2010, 2007, 2003
Read more :- Outlook PST split tool
Ignissta PST splitter is a software tool that enables you to divide a large PST file into smaller, more manageable parts. The main advantage of splitting a PST file is that it helps you overcome the limitations of the maximum size of PST files. When PST files become too large, they can slow down Microsoft Outlook, increase the risk of data corruption, and make it difficult to manage, archive, and back up your emails, contacts, and other information. By splitting the PST file into smaller parts, you can more easily manage and organize your data, reducing the risk of data loss and improving the performance of Outlook. Additionally, smaller parts can be backed up individually, making it easier to recover lost data in the event of a disaster. The PST splitter can also be used to reduce the size of the PST file for archiving purposes, making it easier to store and access the information in the future.
In summary, the benefits and advantages of splitting PST files include improved performance, reduced risk of data loss, easier data management, and simpler archiving. By using a PST splitter, you can maximize the utility of your PST files and keep your information organized, safe, and accessible.
Ignissta PST Splitter tool is a useful tool that helps to split large PST files into smaller, more manageable ones. PST files are used by Microsoft Outlook to store emails, contacts, calendars, and other data. Over time, these files can grow to be very large, which can cause performance issues for Outlook and make it difficult to manage your data effectively. PST Splitter tool helps to overcome this problem by allowing you to split your PST files into smaller pieces.
Try the specialized software. You can separate huge Outlook PST files with the ToolsBaer Outlook PST Split Tool. Outlook PST files may be reliably and quickly partitioned. Owing to their Outlook PST files, they usually have problems finding data. Large Outlook PST files should be divided into several smaller ones using this procedure. This utility makes it easy for users to organize Outlook PST files into multiple partitions according to folders, size, and year. Windows 11, 10, 8.1, 8, 7, XP, and Vista are among the versions of Windows that it is compatible with. Its ease of use makes it accessible to both technical and non-technical users.
Read More: ToolsBaer Outlook PST Split Tool
