windstrings
When do we expect v5.84 to be available in a portable format?
I don't like installing such programs as a "giveaway" on my computer.
I downloaded to my thumbdrive and attempted to install from my thumbdrive to a directory I had set aside for it....
Memory stick support - if it detects then use an ini file instead of registry
I should be able to try the install again and choose to "ignore" that file and see if it works!..
Overwriter said:OK sorted it, I just need to make a link for you to download it.
I appears you simply copied all your files and sent them to me?
