I recently made the upgrade from Windows Vista (64bit) to Windows 7 (64bit) and have encountered a few problems with Eraser.
First time I installed it (that is, the latest version) everything worked fine, but there was one thing I didn't like and that was the new menu Eraser had, which sort of opened queued files and left eraser open in my taskbar. Though that wasn't the reason I uninstalled it, the main reason I decided to uninstall it was the time it took to erase files, it was a lot slower than on my vista computer which quickly erased files by rightclicking then hitting erase.
I figure I'm doing something wrong and can't figure it out. When I tried to reinstall the latest version of eraser I encounter an error and the program crashes. When I try to revert to an older version like the one I had on vista (which was my original plan) it also crashed. So what am I doing wrong?
thanks
thanks
