I am using Eraser 5.3. No, I have no need to upgrade to any newer version as this version is/was working perfect for me for a few years.
Problem: While editing a word doc on an NTFS partition, word crashed. This created an auto recover document. Word recovered my file, and from within word, I chose to delete the recovery file. That sent the file to the recycle bin. I right clicked the Recycle bin icon on the desktop, and choose Erase recycle bin. Now, I still have the Erase Recycle Bin menu choice on the Recycle Bin right click menu. This choice is there even if the recycle bin is empty. If I add a file to the bin, and choose to Erase the recycle bin, the bin is erased and the icon changes back to the empty recycle bin. If I right click the recycle bin again, the choice to erase the recycle bin is still listed. If I choose it again, I get a dialog called Eraser Launcher with the message Recycle Bin is Empty.
How can I remove that Erase Recycle bin menu choice from the Recycle Bin context menu? If the recycle bin is empty, the choice to erase the recycle bin should not be listed.
I'm going crazy trying to fix this.
Thank you in advance for any suggestions.
Chris.
Chris.
