piergiorgio
My problem is that I havn't enough time to complete the desired Gutmann erasing process, because I work in occasional Internet Points where I can stay no longer than 1 hour at a time but I need to erase partitions as big as more than 12 GB contained in my own removable hard drive disk.
My question is : If I stop the Gutmann today, 1 hour after the process has started, will the program be able tomorrow to resume the erasing process from the exact point of interruption without errors, and so on the next days until the work is finished? (Resuming capability)
Or, if not available, could I get the same result of the Gutmann by running the 3 passes method (compatible with my 1 hour pc time) for 12 subsequent daily sessions? (36 total passes against the 35 of the Gutmann)
Thank you very much for your kindness.
