Running DBAN from a partition
lero
Is there a way to keep a little partition with a DBAN installation and in a specific situation change the windows boot.ini to load from this partition and erase all the data with the autonuke setting?
I need a solution that can wipe all the data without human intereference, so floppy, CD-ROM, or USB can't solve my problem.
Thanks.
Best regards,
Lero
ghowriter
agreed
I use dban frequently and have the means to build a dedicated dban computer but don't have the knowledge to move dban to a partition for loading from an internal hd
