Reignwood
Solution:
Locate the folder name you want to delete files from & write down the folder name exactly as displayed including spaces, etc.
Click START
- Click RUN
- Type CMD.EXE
- Click OK
- NOTE -- A DOS window will pop up
- Type CD\
- Press ENTER key (returns you to the root directory on your default drive)
- Type DEL "C:\FOLDERNAME\**" (including the quote marks)
- NOTE -- Substitute C with your desired drive letter
- NOTE -- Substitute FOLDERNAME with the name of the folder exactly as displayed including spaces, etc.
- Press ENTER key (the delete process will begin immediately)
- NOTE -- Pressing CTRL + BREAK should halt the process at any time prior to completing the process
- When process completes, type EXIT at the DOS prompt
- Press ENTER key (to close DOS window)
These instructions are for Windows XP. Vista and Windows 7 users may find that they need to open an elevated command prompt; rich1696 has also kindly provided the following instructions and links.
Instructions for accessing the elevated command prompt in Windows Vista & Windows 7 are at the following links:
Windows Vista: Use Method 3 at the link below
http://www.winhelponline.com/articles/1 ... Vista.html
Problem:
As instructions indicate in first line above is clear; however, the question is: How do I locate a folder that I need to delete in order to remove the files that Eraser program put on my c: drive in erasing free space when no clear description of this folder's name is provided? Here is a copy what the elevated command prompt displays:
C:\Windows\System32>cd\
C:\>dir
Volume in drive C is OS
Volume Serial Number is
Directory of C:\
12/25/2010 03:17 AM 8,338 aaw7boot.log
11/04/2010 01:01 PM <DIR> ATI
12/29/2010 04:57 AM <DIR> BywifiSave
02/03/2011 03:10 PM <DIR> BywifiShare
12/30/2010 07:39 AM <DIR> data
12/26/2010 09:27 AM 2,804,200 pas.log
07/13/2009 10:20 PM <DIR> PerfLogs
02/15/2011 08:58 PM <DIR> Program Files
02/17/2011 10:16 AM <DIR> Program Files (x86)
12/08/2010 01:40 PM 1,301 RHDSetup.log
12/28/2010 12:06 PM <DIR> swsetup
02/16/2011 02:53 AM <DIR> Users
02/18/2011 09:25 AM <DIR> Windows
02/16/2011 12:07 AM <DIR> Xr3sJgiNR`]hc~pf)W
3 File(s) 2,813,839 bytes
11 Dir(s) 3,340,955,648 bytes free
C:\>
Do you see a file that solution applies to? The file labeled Xr3sJgiNR`]hc~pf)W is probably Jing file, but i am not certain.
Click START
- Click RUN
- Type CMD.EXE
- Click OK
- Type CD\
Problem:
C:\>dir
Directory of C:\
C:\>
