Space in pathname
monpelaud
Hi,
I want to delete files in the folder "E:\Documents and Settings\home\Mes documents\" with a .bat file.
I try this command with no success:
eraserd -file "E:\Documents and Settings\home\Mes documents\*.*"
The spaces in the pathname generate a syntax error.
I don't find the right syntax, can you help me ?
Best regards
Use EraserL, not eraserD. EraserD doesn't support long file names.
