Split Outlook PST Software
kineh96808
Split Outlook PST Tool is a prominent application to divide large sized PST files. Free download to split large sized PST file into small sizes as per your requirement. with the regular usage of Outlook emailing increases the number of files that are being stored within PST files which keep on increases the file. Sometimes the large size of the file may result in file corruption and that may affect the performance of the email application as well. to overcome such problems, you have to perform Splitting PST. Visit here for more info: https://www.osttopstapp.com/split-pst.html
You can easily split the large PST files into small pieces in a matter of minutes. There are many tools for splitting large PST files, but I would recommend using the Split PST for Mac to split large PST files into small parts based on the date, size, year, and folder. This tool is fully capable of splitting all MS outlook items such as emails, folders, contacts, calendars, journals, etc. This software supports all Mac OS versions.
For more info visit here:- https://www.mailvita.com/split-pst-for-mac/
Outlook Split PST Tool is software that allows you to split big PST files into smaller Outlook PST files. The Splitter tool's functionality allows users to divide files depending on dates, making it easier for them to identify them. All PST files, including emails, contacts, tasks, calendars, and other data, large PST files can be split using this application.
DRS PST Splitter tool allows you to split multiple PST files at once. It also allows you to process a complete folder at once. Using this tool, you can do away with the unnecessary time that you spend processing each file individually. Try its demo version.
Danish
Sometimes, users look for a solution to divide their large PST files into multiple PST files. Then by opting SysInfo PST Splitter Tool open source, you can easily break the big Outlook PST files without any data loss.
There are lot of software available on the web to split large-sized Outlook PST files into smaller PST. However, only a few provide adequate results. Thus, I recommend using Aryson Split PST Software for splitting a large PST file. Moreover, the tool ensures it doesn't damage or harm any Outlook PST files during the procedure.
AnkitAryson
MacSonik PST Splitter Tool is the best utility to split Outlook PST files without any data alteration. It can break single or multiple oversized PST files into smaller ones by maintaining data originality and security. This PST splitter tool for Mac also provides an option to set the custom folder name and the location of the resultant file.
